wondering about swaps and little hijack ..
Any 2JZ in a Cruiser . ?
hijack off ..
i dont want chevy junk in my Cruiser.
It's a fine little engine,
I agree 100%. Personally I would look for a 1FZ out of a 93 or 94 80. Again you need the wiring harness but the tranny is independent of the engine's computer. Again you would have to source an H151 or H150 but I honestly think it would be very close to the stock mounting. I honestly think it could be done with minimal fab work.
I'm partial to inline sixes. My views are based on the fact that swapping a 350 is well documented, there are many tuning options for them, and they are cheap. Also you don't have to worry about a computer if you get a carbed version.”
The 2UZ has no cheap tuning options
requires a computer,
if you're using a North American computer you are limited to using an A343
And it has a timing belt.
I suggested a 350 when the OP stated that a 2UZ swap would probably be too expensive. If you want V8 power and don't want to spend time figuring out the wiring harness, custom ECUs, etc, a 350 is the logical choice.
no way anyone can argue that the sbc isn't a good motor.
Sure, they work![]()
So you are going to swap a carb’d push rod motor for another card’d push rod motor? That’s worth the effort.
They run just peachy stock, but, there is a lot you can do mixing UZ parts. Superchargers can be found for reasonable. Beyond that, you will have to open your wallet wide for any power plant, but, it really isn’t warranted.
So does any modern engine with EFI. Carburetors? WTF, Are you crazy?
Like I said before, I’m not read up on what you have to do, but, manuals have been put behind them, as have domestic autos, I’m pretty certain you can fool the ECU. However, the 2uz a343 combo rocks.
Oh My God, NO! It has a timing belt! It has to be changed every 100K! Give me a break, as long as the required maintenance is done, the belt won’t give you trouble, Its an easy job.
Once again barf. You can get a complete 2UZ for $1500 and less all day long, they are in a ton of trucks. The wiring is not hard, but you won’t understand that till you see the harness. Your argument reads like, “If you want a V8, bury your head in the sand and use a SBC. Why you ask? because that is what has always been done! Don’t question me and the gods of push rod V8s! Furthermore, do any and everything to put a straight six in, I like those.”
In the end, its just a little bit more effort and a little bit more money to end up with a much nicer conversion, with a much nicer powerplant. I wouldn’t touch anything with a s***ty SBC, but, maybe that’s just me.![]()
I am going to try to mate it to a H42/ Split Case. I will be building a custom bellhousing by taking a 2F bellhousing and cutting the engine side off of it and welding on a flat plate drilled to 2UZ pattern, The amount cutoff and thickness of the flat plate depends on the depth difference between bellhousing surface/ crank face surface on the 2F vs 2UZ-FE engine block.
Probly don't need 2 VSS's. On the applications that have 2 separate VSS, one feeds the ECU and one feed the instrument cluster. If using the Cruiser t-case, the stock speedo cable can be retained to drive the stock speedo. The 4 prong signal generator will feed the ECU.An additional VSS may be required on the t-case output where the speedo drive gear attaches but I don't know for sure.
Any 78-newer Cruiser has a robust evap system built into the chassis. Is it necessary to remove and replace w/ a different evap system? Worst case, the old system won't play nice with the newer ECu and it will throw an evap code. It won't go into limp mode. The ECU can be reflashed to eliminate any evap monitoring.The next computer item is the evap system/ charcoal canister, this would be adressed by using the charcoal canister that comes from the Tundra which I believe is the same unit used in several toyota vehicles including the tacoma. The donor vehicle system would need to be mimicked.
You're definitely on the right track.Additional items needed are an electric fuel pump capable of putting out 38-44 PSI, and a fuel return line from the fuel pressure regulator which is mounted on or near the fuel rail (my 79 has a fuel return line to the fuel tank already) A CEL would be installed in the guage panel.
I believe that this would allow the engine to run/ drive without throwing any codes or going into limp mode.
This sounds pretty straightforward. Some people say it will be impossible to get a good weld between the thin, brittle cast iron BH and the ~3/8" mild steel horseshoe that will be welded to it.
