NorCalBorn
- Joined
- Aug 31, 2008
- Threads
- 102
- Messages
- 1,856
Since I know you can modify an earlier model relay to stop the fast flash symptom when doing a turn signal integration
using either a smaller wattage (RESISTANCE/DRAW) bulb or LED. I thought it might be a good idea to try it out on one of my spare relays.
I'll say after trying 4 different ways of either shorting or bypassing the resistors, I am still unable to stop the fast flash on the 81980-12070 relay.
If someone with more electronic knowledge wants to tackle and solve this all the power to you, and post the solution for the rest of us.
The word cloud points highlight the areas I've already tried, each respective resistor tried only once before resoldering and trying another point.
*In other words, I fixed the resistor if the attempt didn't work to verify it was still an operable system.
I also want to note that cutting the pin7 LD (Lamp Failure Detection) circuit from the IC chip of the OE relay DID NOT work...
