2F TBI adapter & throttle cable? (1 Viewer)
Utah
Which TBI adapter would you suggest for a 2F application using a GM 4.0 throttle body?.. I know some make it so the TBI is reveresed and make the throttle hookup harder.
Wasn't there an adapter that made the throttle connection so you can use most of the stock pedal setup with some mods?
I only know of Downeys and not sure Mike Smythe still makes them.
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
Make your own... <---- this is a link
Not that big of a deal really. You can then make the throttle body face however you want to.
Mike is no longer making them....
:beer:
Rogue River Oregon.
Hey Poser,
The TBI adapter link is not working for me, is there another source for the layout?
I am having difficulty with the layout
Heron
Poser
Supporting Vendor
MN
Try it now....
Downey
Brea, Calif.
Poser, I took a gander at the link you referenced---I don't get it!!! (a) why would anybody go through the exercise to convert a 180 degree straight VSS into a 90 degree unit---what did I miss??? (b) Why would anybody use a buffer, not reprogramable, no suited to his tire size and gear ratio, and admittedly did not work?????
Poser
Supporting Vendor
MN
Jim-
If I recall correctly, that article has been out here since 2003, and the conversion was done back in 2001. As you and I are both aware, many things have changed since then, not only in regards to TBI setups on previously carbureted engines.
:beer:
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Downey. It's simple and works. Plus you get good customer service. Post a pic to the TB. There are a few types.
