Travis, the coil negative goes to one side of the points, with the other side connected to ground.
The plus side goes to the ignition switch.
If you disconnect the positive, that will disconnect it and prove that the noise is related to the coil or points.
Another thing that you can do is to check it out in the dark and look for arcing. It could also be points arcing if your capacitor is bad. Capacitors are cheap.
G'day edgjmcgrath,
Thanks for the support! I will try what your a suggesting but im yet to get my head around it lol. So, you want me to remove the + connection to the coil, leaving the -ive and the lead between the coil and distributor in place?
With no +ive connection i would assume nothing would happen at all, the engine would not start and the coil should make no noise as there will be no power supply to allow the coil to charge.
Hmmmm, im in way over my head now!
The capacitor you mention, i assume you are referring to the 'condenser'?
You are correct re: the location of the -ive wire from the coil, it runs down to the distributor and connects under the same terminal as the lead off the condenser. Perhaps something is bad there.
Ive just come back in from the garage - its 1am here now... and fired the old girl up much to my neighbors delight im sure
Looking everywhere i could not find any sign of a spark.
I must say it was my first time poking my head into a running engine bay in the pitch black! Was quite an experience. I didnt touch much, but the highlight was i found that anywhere i touched the lead between the coil and the distributor made the lead glow just a little bit, as did it where ever it came into contact with something else in the engine bay! Very cool!!!
G'day TTR!
Thanks for the kind thoughts mate, yes this is doing my head in.
As above, i couldnt find a spark and fwiw before buying the new coil today the guy at the auto parts shop let me take a new lead between the coil and distributor and try it out - but the clicking remained thus i bought the coil... I didnt realize the problem could potentially come from one of the spark plug leads? I have my old leads still (ones on the car right now would be 12months old at the most) i guess i could grab one of the leads and one by one try it in place of the spark plug leads and see if the noise goes away.
Just to be extra clear, the noise is coming from the coil. 100% positive about that. Id have thought if a lead was arcing etc... the sound would originate from that area.
Everyday i go from thinking this has to be a head gasket to not... enjoying learning more about the old girls heart but it really really is bad timing so close to Xmas.
My mechanic said the same thing re: the Leakdown test and Hydrocarbon test... He did try and load the engine up (during the hydrocarbon test) but there really is no comparison for the actual loads while driving. He said something along the lines of the Leakdown test pressures are 'X' amount, but the actual pressures during combustion would be 'X' x 'X' so perhaps there is a very small leak that simply does not show up in the above tests.
And here i go once again, im thinking maybe it is head related....... BUT once again, after all this time shouldnt i be seeing some coolant usage, exhaust smoke / steam at startup... condensation under the oil fill cap, contaminated engine oil, contaminated coolant etc..........
BUT how come the cooling system appears to 'pressurize'!!!!!!!!!!! hahahaha, around and around in circles
Thanks again guys, greatly appreciate the support.
I will try and update / add some more photos to the trip report tomorrow!
Travis.
