- Thread starter
- #21
Thanks again guys.
DP - your spot on there, IMO the cooling system on these old Toyota's is over engineered and when functioning properly allow the old 45 to carry a full load across the outback without a hint of overheating!
Thus, i knew something was up the second the temp gauge needle moved above its usual position.
So far would i be correct in assuming that the radiator hoses should NOT really pressurize during operation, or at least not while the engine is still cold?
Assuming they are, is there pretty much only one possible cause??? (combustion gas entering the cooling system... or something entirely different)
Or is it plausible that some blockage inside the engine would cause the radiator hoses to pressurize?
IMO, i would think that if the hoses are pressurizing almost immediately once the engine has started that this could not be due to a blocked coolant passage within the engine as under normal operating conditions there is NO flow in the engine until the engine reaches the opening temperature of the thermostat and its opened.
Perhaps one could even go as far as saying a blockage in the engine if anything would potentially cause the lower radiator hoses to 'suck' inward on themselves as the water pump draws liquid from them, just as one would expect to see the lower hoses suck inward if the radiator had a substantial blockage?
Then again, with the bypass hose, perhaps that isnt true for the engine blockage as the water could simply bypass the engine...?
Then again, again, i worry that by over analyzing this and looking hard for a problem... what if the hoses are not really 'pressurizing' any more then normal? Can anyone tell me what is normal? Given the hoses are all brand new, and replaced hoses that were at least 16years old it may be possible that the new rubber is simply softer??????
Then again again again, i guess im really over simplifying this as im thinking substantial blockage. I have no idea how many cooling passages are inside the engine and how they are laid out. Is it possible just a small part of the engine to be blocked while the rest functions as normal?
ed- With regards to running the engine with the radiator cap removed, in the passed i have found that from cold (engine) once started within one or two minutes the coolant will start to overflow from the radiator. In these cases ive simply quickly fitted the radiator cap.... and thought WTH lol, how do these guys to it online! FWIW ive experienced this for as long as ive had the car. I do not believe 'overflowing coolant' related to a head gasket failure etc. As the engine heats up and expands, if the system is 'full' it is going to overflow. (Its just when reading on here, id never ever seen mention of leaving some coolant out of the radiator, or expecting some to overflow...)
So i guess it makes sense, you basically need to drain out the equivalent amount of fluid that the overflow bottle usually rises by when the engine is HOT. Ie. 1" to 1.5" of coolant in the bottle - as you said maybe a cup or two.
I will do this and let you know how i get on.
And yep, as per the first post, engine leakdown test was done and came back a-ok...
BC - yes ive always try to removed any potential air locks from the cooling system after refilling it following the method you described. Parking the old girl up on a very steep hill and running the engine, squeezing the top radiator hose too... to try and 'burp' it. Heater tap open etc. I usually repeat this for 2-3 days each morning. As it 'burps' i then 'top up' the coolant and repeat.
So far im getting the vibe that this pretty much has to relate to the head gasket. If only 'THE' tests agreed! An engine running hot MUST relate to the spark / ie. running lean OR something relating to the cooling system? Nothing else.
So, if the engine is running good, it cannot be related to the 'spark'? Which leaves only the cooling system...
I really dont want to overlook something else.
Travis.
Travis.
