2F Redline
Southern Arizona
Folks, I've looked for this and well I do not seem to be able to find it. What is the factory redline for a stock 2F (8/78) and what redline can you safely expect in a rebuild that uses high performance parts and has all the rotational components balanced. This would also include an upgraded tuned header and exhaust, carburetor and ignition but maintaining the emission control (not willing to move).
Andewfarmer hit 7K with his 2F
I know I have hit 6K with mine..
Balance, balance, balance...
smash the gas till you feel like its going to come apart then let off...hehe
with my 1F i can hit it to about 4K but the 2F in my 60 seems to want to only rev out to 3800 before its time to shift...really the only difference between to the 2 is the 1F does have the weber on it....but the only time im hittin it that hard is to keep up with the old man in the rusty escort next to me taking off from the lights...i always lose though
Old factory stuff lists the peak power of the early 2Fs at 3600 rpm. Redline on the stock tach of a '60 is marked at 4000. On a '62 (3F) it is at 4500.
I'll turn built 2Fs 5000. I routinely turn them to 4500. I'm looking at some stronger rod bolts to increase confidence above this, but I doubt that I would choose to push the cast pistons to 6000
Folks, thanks for the response! I need to look at what would be an appropriate rod bolt upgrade. Would either grade 9 SAE or 12.9 metric be an improvement?
Mark, what rod bolts are you looking at?
I've been considering an ARP rod bolt for a big block Chevy. Only a couple/few of thousands larger diameter than the factory bolt.
Mark...
i took mine to 5500 all the time then BOOM
That pic gives me the shivers. I say that never gets shown again:ban:
I've got a couple/few blocks on the scrap pile that look a lot like that.
Not the rod bolt with no nut on it sticking out the hole... Dollars to donuts the bolt stretched releasing the torque on the nut. The nut came loose and the result (some of it anyway) shows pretty clearly.
Mark...
Mark...
Mark,
After going through the ARP catalog and reading their engineering - well I'd like to use their rod bolts. Can you give me more info on what rod bolt you found that will work and what the part number is? Thanks
Barry
Why would you even want to reve it that high ????...cruisers are built to go slow with lots of grunt....IMO
That is absolutely true. I like to over build, run it through the gears and cruise past J**ps on the interstate .
lots of jeeps here dont care if i passem in 36 years will that wrangler still be here hook up the chain who pulls who at the car shows the cruiser draws a crowd jeep guys are lonely and come over to chat nice guys pulled em out a few times .they pulled me out once they may wave when they go by on interstate but thats where it ends atoy is atoy ive towed 7 6x6s home to my house 13,000 lbs 5tons of scrap on my trailer with my 2 f havnt seen any jeeps do that if you have to beat em go to a v8 and and auto and cruise at 75 all day long good luck hope you win
sand and mud..
Mace said:
sand and mud..
x2....and sometimes you just gotta give it a bootfull!!! It's always nice to know you've got a bit extra:)
