2F overhead cam?
The cam sits low in the engine a little higher than the crankshaft. It comes out and goes in from the front.
“HERE” is a short vid of one going in.
Are you planning on removing yours? We can walk you through it.
Gosh, thanks!
I've got a knock...
(see youtube link below)
Kb
Bottom end. Run it up on a lift, drop the pan and check for play on the journal. Just went through this…I only had some glitter in the oil. No knocks, just a bearing going south..
OK good to know.
Main bearing?
Dipstick oil is amber and clean. No grit, no flakes. 50 kilometers on a rebuilt top end. Valves, pistons, not rocker arms, pushrods or cam.
Kb
OK good to know.
Main bearing?
Kb
Sound coming from bottom end?
Im old and deaf, cant tell from the vid. Crazy exhaust sound 😳.
