2F Head Gasket Re-Torque Required?
Does the OEM head gasket need to be re-torqued after initial installation? If it does:
1) How long before re-torquing?
2) How do you get to the head bolt that is under the valve train? Do you need to pull valve train to re-torque?
Thanks.
According to Toyota, the new version of their headgasket does not need to be retorqued. I still retorque the headgasket after a couple hours of light running.
I torqued mine with a new 1/2" drive SnapOn when I built the motor and 50 miles later retorqued the head and all the head bolts had lost 10 lb/ft of torque.
I was surprised. And that was an OEM Toyota gasket, same wrench. You need to readjust the valves anyway after removing the head, so go ahead and check:)
GL
Ed
I have yet to find any head gasket that consistently does nopt need to be retorqued. it is easy to loose up to 30 pounds of torque after the motor has heated and cooled a couple/few times.
Assume that you need to retorque the head, regardless of what the gasket manufacturer claims.
Mark...
