2F exhaust routing
The Rockies or the Andes
Can the exhaust from a 2F be routed next to the frame rail (on the inside) under the drivers side floorboard and above the stock skid plate?
Would I need to wrap the pipe to prevent it from overheating the drivers side floor?
If I do it is there a better place to put the muffler?
Edit; This is the 2F on the 40 in the sig.
IanB said: Can the exhaust from a 2F be routed next to the frame rail (on the inside) under the drivers side floorboard and above the stock skid plate?
That's where mine goes (on my '75 FJ40). But it does send a lot of heat up through the floor. Wrapping or otherwise shielding would be a good idea. I've been thinking about adapting a catalytic converter heat shield from some other vehicle for this purpose, but I haven't got around to it yet.
Ian, you do not mention if you are running a stock manifold or headers. If you are running headers, then routing is a simple thing. If you are running a stock exhaust manifold, there are issues.
The stock exhaust pipe is a sleeved assembly, which is designed to help deal with the heat, but has piss poor routing. If you cut into that pipe, you will find it is VERY DIFFICULT to modify. Further, the collector that bolts onto the stock manifold is very size and orientation specific, so moving it to a single wall exhaust pipe is also an ordeal.
May not be what you wanted to hear. :frown:
