Wanted 2f carb
Status
Not open for further replies.
Portland OR
Aisin carb for 2f with manual choke. Want a rebuildable core. Anyone have one in good shape?
can you be more specific? there are several different versions that meet your criteria. any carb from 1975 thru 1987 in the US
A 77-79 2f with manual choke. I don’t have a part number.
The 2 carbs At the top of the post or both electric choke but thanks
77-78 carb would be what I'd be looking for
the later 79 was not the best available
I've never seen an Aisin Landcruiser carb for the US with an electric choke. the wires you see are for the idle solenoid
Thanks for clarifying. I’m not an expert. I have a Holly and a Webber but never actually seen the correct carb.
FYI most likely you will need everything else associated with the carb,
full throttle linkage maybe including pedal assembly
air cleaner assembly
pics of your current setup will help get you all the correct parts needed
It’s an aftermarket throttle cable and Downey air cleaner.
That Downey air cleaner should make good trading bait. @GA Architect
Status
