295/16-18 on Bronze Method Roost
SLC
Got em mounted up today, obviously an extreme amount of rubbing in the front at this point. Got some serious cutting tonight as plan is to leave running boards on for time being...
Running Ironman FCP Suspension. Might have to wind up the coils on the front a bit.
Looks fantastic in person, very pleased.
All trimmed up. Went from being barely able to change lanes to no rubbing on the street. Probably require some more tweaking for off road but we shall see.
What type of tire pressure are you guys with larger tires running? Discount recommended 40, it seems they always quote far too high, maybe 35 is reasonable?
Depends on tires, I run 37 on my current Geolanders that call for 40 psi max I believe. And on my old 80 I had Cooper Discoverer MT's that had a max psi of 55 and I would run 50 psi in those except down in Mexico since the roads are so beat down their.
I suggest using the stock pressure. Remember that pressure is not the same as volume. The main reason to change would be dependent on the sidewall stiffness such as E rated tires.
