275/70/18 challenges
OE Tundra wheels have the same offset. Difference is the front hub doesn't stick out as much as on the 100.
pics.
Offset should be fine. What are these spacers you speak of and why can't the wheels fit without the spacers? Picture?
I know what the deal is now. thanks for the guidance. Here's the pics since I promised.
I'm a little confused by this. Aren't the wheels for these trucks hub-centric? If the Tundra hubs don't stick out as much, does that mean that Tundra wheels on a Land Cruiser might make the hubs appear to be sticking out further than they would on a wheel designed for a LC?
So essentially just a cosmetic issue so long as the hub bore on the wheels is the same and the wheels are making contact with the hub?
Yes, the bore diameter is 110mm on both the Tundra and LC100. Many Tundra wheels will fit, but the plastic center cap doesn't often fit. Depending on the wheel design, sometimes the bore is not 110mm all the way through and the face of the wheel interferes with the LC100 hub.
It is not always just cosmetic, like the case with the 17" Tundra Rock Warrior edition wheels. They require either a spacer or the hub to be bored out all the way through the face to work.
https://forum.ih8mud.com/100-series-cruisers/433972-tundra-wheel-issue.html
