god, it's like a post on this subject once a week, and I'm getting tired...
Not in the, "you're a newb, search!" kinda way. I just H8 looking up the stuff I wrote in like 30 different threads, and I either don't care to search for them, or I forgot where they are.
I just H8 saying (having to type) the same thing over and over again.
stock turbo's are junk. costly to rebuild, so you shouldn't. They aren't very good units anyway, and H8 the heat.
the stock manni's love to crack. replacements are cheaper than going the custom route.
they put out 7psi.
the best thing to do is swap a supra turbo in. it is lesser prone to cracking on the intake side than the stock CT20. the CT26 (supra turbo) also puts out only 7psi but is has a lot of aftermarket support so you can mess with the boost if you like. The CT26 has more CFM so adding an intercooler will have less of an effect than say, adding a intercooler to the CT20.
the ct26 upgrade is not hard.
there was a guy on FleaBay selling rebuilt Garret T-3's and custom exhaust manni's for Toyota 22R's for $400. That is an awesome deal, considering the support for that turbo...and the fact his exhaust manni is probably better than Toyota's
Sweet thanks I'll check it out. I was told if I did need a new turbo Garrett was the way to go.
Then you'd have to do this:
From this thread:
Turbo 4runner
yeah, it is true you can do that, but it's my nature to tell you the most economical way to do something. I just H8 seeing people spend money
I'll try to find the RTE forum, it's got a great How-to in it about using a CT-26
ahhh, looky here...
22RTE - EFI and Tuning
more specifically here
CT26 Installation
Also, with a relatively low c/r even for a turbo. You should be able to mix and match the 22RE pistons OR (not and) an RE head. And so you know, a RE block does not have the turbo oiling provisions drilled and tapped like the RTE already does. (not a real a biggy)
The stock Turdblow only puts out 7psi, the CT-26 does to, but it has more volume so it would lend it's self to an intercooler and turbo mods better....
Ala LC Engineering...(**MUST READ**)
(fixed)
General Automotive Tech: 22R Block and Head Identification
Just so you know, anytime you add power you lose some engine longevity. But there are lots of improvements that can be made on that engine that are not over the top.
I was also told the reason why these are rare finds is because its rare to find one that is currently running.
lol, das is true
I might have left some thing out...whoops, like a guy on
EBay that sells rebuilt T-3's and CUSTOM ex. mannis for $400...
I haven't seen him in a while but I bet you can still find him. He might have his own site by now.
https://forum.ih8mud.com/79-95-toyo...sticky-blow-off-valve-22re-t.html#post3700875
