22RE Warm Engine problems
I looked the codes up and I'm thinking I need to readjust my TPS but I'm not sure about the knock sensor and the code 43
Code 52 is one of your main issues with loss of power. You'll need to figure out if the knock sensor or wiring is bad. The knock sensor is sending your truck into limp mode after you rev it up a bit. If it's a bad knock sensor it's okay, CDan or Beno can get you one for about $190 haha. I had to buy a new one for my 84 with 89 efi in it.
I'm talking Toyota OEM
41 is throttle position sensor. Don't mess around. Go get a new one, sounds like that's your main issue. Others are stater signal and knock sensor. Check for shorts in your wiring....
Good place to purchase electrical components and/or sensors?
I have to agree with toast on this one. Everything electronic I've bought aftermarket I'm on my second or 3rd of
PM Cruiserdan and don't look back. Good guy. Good friend.
I'll warn you now, he's out at cruiser Moab this week
That's fine, would like to test my TPS before I purchase a new one
TPS could be out of adjustment or sticking. There's an earleir post in this thread to 4crawler's site. He explains the process very well. As for sticking pull it and lube the shaft, man that sounds bad. If those two fail time for a new TPS.
Yep, I agree....do any of you know where I should start on trying to figure out why my speedo goes straight to 90MPH when I start my truck and then stays there
