I have an 86' 4 Runner with a 22RE, I parked it for about a month, the next time I fired it up it started as usual with no indicated issues, then cut off and would not restart. Just befor it cut off there was an indication of the engine starving fir fuel.
Ive checked all the usual causes yet it seems to be running on the cold start injector, once the cold start injector cuts off so does the engine.
Fuel pump cheeks out good
I've replaced the ignitor with a knowen good ignitor
When I manually open the AFM the fuel pump turns on
This weekend I'm going to dive into it more, but if anyone has a suggestion outside of check for codes and use the FSM ID really appreciate it.
