2026 40s Only Run
I'm definitely in the "Going to need more parts before fun" group. I haven't done anything to the 40 since we looked at it. I somehow managed to delete the my notes on what I need to do to get it going. Mainly rebuild the carb and new gas lines. Can't remember beyond that though.
I think we determined your fuel pump was bad too. And your clutch didn't work. Good first steps.
I'm likely out this year. We're in the middle of a leadership change at 911 in addition to all my summer tower site work. I just don't know if I'm going to get my engine torn apart and back together any time soon. I'm going to have to schedule some time off just to have time to work on it. :(
I hear ya. But I'm still marking you down as "In". :hillbilly:
We’re running. I’m chasing a few issues. I’m hoping for a burger at Marks next month with the club.
I got my 40 running again. I've got a bit more work to do on the timing. (I ran out of adjustment at ~16 BTDC and need to rotate one tooth) I think I'm going to try to put some LED taillights on because I'm tired of fixing the OE lights after every trip. I'm really excited to see @REZARF and @bagochips76 at this event!
As pure usual, I have a pile of portable radios with HAM and GMRS frequencies programmed that I can bring along for anyone who is lacking a radio.
I struggling to get the 40 running. Not sure what’s happening, she fires right up but won’t stay running. I need to work on it more. Spent all day Saturdays dinking around on it.
Drew, it will fire and start while key is activating the starter? does it die as soon as the key is in run mode?
or how soon does it quit running after the key is back in run versus start?
Yes, that sounds about right. I think I need to double check all my connections. It seems like the ignition isn't getting signal when the key is "on"
I also swapped to an FJ60 ignition and dizzy years ago and I have had a few issues with the ignitor in the past. I love the electronic ignition but it has it's quirks. Could be that I was 22 when I installed it and didn't know pos from neg wires. ;)
This is from 40s Only runs with the Rising Sun Club. May you have
a breakdown free outing!
being as you have power in the circuit in the start position I would,
check and see if you have power in the circuit when in run
I think that’s the right plan Paul. I appreciate it. I have good clean fuel, good fuel pressure, good spark at crank. It’s gotta be something simple I’m missing.
Drew have you checked to make sure that your idle cut solenoid on your carb is getting 12v and is getting a good ground?
If I can get the carb tuned correctly, this may be the most mechanically sounds my truck has been for one of these runs. Still don't have a functional park brake, but that's asking an awful lot for a 40 to have a functional park brake.
I'd rather get it tuned adequately, but not good enough that it makes me second guess upgrading to fuel injection.
I’m running. Not driving… yet but running.
Gotta run the rear and mid harnesses, rewire my new tail lights for the proper 4 pin connector. Then a shake down run or two.
I see daylight. Big thanks to these guys for the help!
I'm still fighting with timing and carb tuning, but I think I'm close!
