2021 Shock Therapy
Damm, everything really must be more $$$$$ in California.
LOL....I call it the Kali fun tax, and if it is not "taxed" in some way and it IS fun, it is most likely illegal or someone will otherwise be upset at you for doing it.
My bigger issue with buying a welder is that my ancient electrical panel in my house was recalled in the 80's and very few electricians will touch it, let alone add to it. I'd need to replace the panel and the probably underground feed line (which is an aluminum feed...who does that) ...and talk about a Kali fun tax-electricians charge BANK for their work here. At somepoint we'll need to do it when you can only buy electric cars in Kali....Rivian anyone?
I kinda thinking I just buy once, and cry once and go with the DVS arms and sacrifice a virgin to a volcano to protect my rocker panels for the time being. Is there a market for slightly used radius arms and 4 new bushings :hmm: ... Maybe the land cruiser gods will smile on me with a set of sliders that fall from the sky!?!
Would love to hit Joshua Tree regardless!!
Honestly sliders are a little over rated.... if your not planning on doing trails like the Rubicon or playing in the big rocks than you should be fine without them. They are nice for piece of mind but a lifted 80 on 35"s have a fair amount of rocker clearance.
The majority of use my sliders receive come from other car doors. I always laugh when someone parks in the stall next to me and "rides the line". They usually proceed to open their doors and SMACK, they dent their doors on my sliders.
Ha...yes. Sorta like my ARB bumper has only really protected me from that time I detonated a random wayward garbage can on the freeway and that other time back hoe that backed into it... (it's better as a video, but you get the idea)
Alright folks! I joined the Delta VS arms club today. Ordered up a set with the bushings, killing two birds with one stone!
@Delta VS rocks, thanks for your help and making a bomber product!
Also turns out, I botched my partsouq order an somehow have 4 extra panhard bushings, and only 2 axle side bushings....whoops....will either be selling them or returning for a restocking fee. (totally my fault, I have no idea how I managed to #$#% that order up so badly. I'm a total :banana: :rofl:
@Delta VS
Hotness!! Packed very, very well, love seeing the made in USA sticker on the box too.
My UPS driver knocked on the door saying: I have a box of concrete in the truck for you.
I worked at UPS for a while in college loading the semi trucks. These kinds of boxes were brutal... the worst though were boxes of ball bearings, leaf springs, textbooks, etc.....
Those arms look great!
Progress.
Rear is done. Front shocks and Springs are in.
@ZackR dope tip on the bigger jack stands. Would’ve been impossible without them. Thank you.
Only snafu so far. I totally buggered one of the rear lower shock mount bolts so had to find a 10.9 bolt at the hardware store till I get a new one with that weird washer.
the pile of parts for tomorrow. Paint is drying on the tie rods
had a helper. He helped me figure out the order of the washers, mounted up the sticker and LOL we mounted the top brackets upside down. And almost mounted the whole thing upside down until I realized it was an upside down shock.
IMS beef.
currently...super stinkbug. (This was before the front springs). New tires ordered, not here till next weekend.
Also took measurements ground to panhard bolts and fenders to wheel centers. Will post those for ref. And add it to @Delta VS database too, once I get caster # at the end.
Making progress, I like it.
I feel like this is supposed to be flat??? Not with a wooop in it?? Plate that connects the steering damper to frame?
mount it back up? New one? Try to persuade it back to flat? Part number?
Welp. So as not to bugger the inserts in the frame....I just Bolted it to the frame in the holes for left side steering ( thank you mr T for you kaizen) and belt her back to spec.
Got her done. Except for an unexpected second snafu with the bolt for the steering dampener.
Seems to have stripped itself on the stud. Just free spins, but also not coming off or going on. So guess I gotta get a nut cracker. Then get a new mounting stud. So dead in the water.
One a good note the delta arms both went in without any drama.
I mounted frame side nut, then middle, then jacked the axle a smidge and used a prybar between the axle and the head of the front bushing till the bolt lined up and pop! Easy peasy. 20 mins a side.
measurement coming.
Got the steering dampner on! 10 min job, with the replacement stud bolt for dobi's. I'm very happy I chose to work with exit offroad on this project! (lol paint job on the steering link already looks used).
A Question:
I haven't inserted the cotter pins yet in TREs as I figured I might need to make some adjustments...like re-centering my steering wheel (see next pic)....but I noticed that the castle nut is below the the pin hole in the bolt. This is the only one like that. I did torque to FSM spec, to get the pin to go in, I need to loosen by 2-3 turns. Would this be "tight" enough, are they over torqued? the other 3 are seem ok, might only have to back them off by a 1/4 turn or so.
A Question:
Loosen and remove the nut, then place one or two flat washers under the nut, then retorque the nut and insert the cotter.
That tell me that the taper is cut too deep or the nut is incorrect height, but it's a simple fix.
So my wheel was always a little leaning to the left, figured I'd fix it after a lift, either the lift and or the new steering kit or the noob the at installed it, exaggerated at bit more....tracks pretty damn straight though.
Adding this to do the list...
Simple adjustment on the drag link from the steering gear to the RF steering arm. That's about 3/4 turn one direction or the other on that rod.
Awesome thanks! I sent marlin an note about this too. They really should machine a wrenchable spot on the ends of those rods...
Don’t get the pintle/ball combo. Or if you do, just don’t put a strap on it or use it to recover anything. Regular pintle hook is a great recovery point on stuff, but I scratched the ball right off one of those with a backhoe bucket pulling a pickup out of the snow. I had heard that people didn’t like them, but I’ve seen it for myself now.
Thanks, yeah...I was looking at this one from holand where the ball is forged on vs the bolt on "cannonball." But, with the lift I'm not going to be able to tow anyway without a drop hitch, so I've got to figure out how to mend the busted captive nut in the frame rail, so I can put the port installed receiver back on. (I don't want to weld it back on if I don't have to) I talked to the sales rep at rivnut yesterday, they said a 12mm rivnut would work....I somehow find that dubious. Plusnut have a higher pull out rating, but only go up to 3/8". Needless to say, I'm heading away from the pintle at this point anyway :(
@BILT4ME guys at marlin got back to me and thought my pitman arm hole has been wallowed out....seems like a long shot no?
Looked at my passenger side 555 and it is now seeping grease from the boot. Will try the washers when I get a chance to pick some up, still seems like that would flatten the boot too much though, or is that not a problem?
For fun I tried my old one....and works just fine at FSM spec.
Found an old thread in the 40 section that looks like same issue too: Brand New Tie Rod Ends - Is this Normal? - https://forum.ih8mud.com/threads/brand-new-tie-rod-ends-is-this-normal.775450/
