Clutchee, you need to bring that 4R over and pimp that sucka. She's a beauty!
4runner is DD;40 is making tripClutchee, you need to bring that 4R over and pimp that sucka. She's a beauty!
V-belt? Will it tighten at all? V-belts can withstand a little misalignment. And they're pretty cheap usually so grab a spare on the way and roll with it. If not, can you put a tack weld or two for now? Or if it's aluminum, JB Weld the holes with the bolts in place but lube the threads of the bolt so maybe you can unscrew it after the epoxy hardens. All else fails, just bring that junk and we'll make it wheelable somehow!power steering bracket isn't going well; as in holes are wallowed out and won't allow belts to align.
Anyone coming across 40 west through Memphis take Hughes exit before construction run the old highway runs parallel to 40 till past Forrest City. I usually leave early to miss this but today have been here 40 min and moved .5 mile maybe.
Thanks Bomar!Anyone coming across 40 west through Memphis take Hughes exit before construction run the old highway runs parallel to 40 till past Forrest City. I usually leave early to miss this but today have been here 40 min and moved .5 mile maybe.
Thanks for the tip. IH8- The Memphis/Little Rock stretch. Worst hwy in 'Merica
Truck of tires caught on fire on 40. She is back open.
Was the truck fire the only reason for the traffic problems, or is there also construction?
Hijack on---
Your trailer has sliders??!
Hijack Off---
