2013 GX owned for 2 hours. Help me get started!
If one is seeing AT temp over-temp indicator I would make every attempt for a full fluid change at that point as over 300 degrees. I will have to look at '20+ indicators.. this is 14-19 first and then 10-13
EDIT: OM just states this warning message will appear for 20-23
14-19
10-13
  • Like
Reactions: r2m
The "overland" cat-back, or the stand alone 11226 muffler?
Standalone muffler with the factory resonators intact. The 12255 Magnaflow, which is larger and quieter than the one you linked to.
I have the Magnaflow Overland. It does provide some extra growl. I got it mainly to get the exhaust higher up so as not to catch on the trails. It works great for that.
For dashcam, I have a nexar. It pairs to your phone and uses it for storage of videos. Came with a VERY long ISB cord and an interior panel removal tool so you can tuck that cord out of sight.
I've seen more negative than positive for the grom vline. I'll stick with stock and use a phone mount.
I don't tow, so no advice on a transmission cooler. But 12 hours in 4 low in 118 degree heat and I never had issues.
I have a 2021 GX, so I already have a household plug in back
I have 3m ppf. It helps, but it all depends on your trails.
From reading I know you don't tow, but do you have the factory hitch?
I don't know, but I'm just going out on a limb and taking a crazy wild poke in the dark that you... tow... AND that you tow a boat!!!
Yes, I have the factory hitch. I use it to pull out my friends rig when he chooses the foolish path and gets stuck. I use it a lot. A. Lot.
That's amazing. Did you have any issues fitting the overland exhaust around the factory hitch? Or any problems with it rubbing/hitting?
I wish I had a boat! No, I just picked up my GX this past week. I want to keep the factory hitch as I'll use it to tow a camper trailer, toys, etc.
  • Like
Reactions: r2m
