2012 Viper Winch Pricing
Chesnee, SC
VIPER ELITE Recovery Winches
The absolute top of the line winch - every feature you could ever want!
COMPONENTS INCLUDED
•Wireless & 9' Cabled Remote Switch
•Circuit breaking "on/off" switch for safety
•Fully submersible, integrated housing
•85' x 3/8" diameter Patented AmSteel®-Blue Synthetic Cable
•Hawse Fairlead
•Large Clevis Hook
•6ft of 2 gauge wiring
•Handsaver Strap
•8T Snatch Block
•Waterproof Winch Cover
•Installation Hardware
•Lightweight design for easy movement - just 75lbs shipping weight
•Mount Pattern: 10" x 4.5"
•2 Year Warranty
AmSteel®-Blue SYNTHETIC CABLE
•Max load rating of 20,000 lbs
•3/8" x 85' diameter
•No recoil - VERY SAFE
•Easy to use
2" RECEIVER CRADLE AVAILABLE
•Add the 2" Receiver Cradle for extra flexibility
•When purchasing, you have the choice of adding (for an additional charge):
o a 2.5' and 5' wiring harness for the front of your truck
o a 2.5' and 24' wiring harness for the rear of your truck
oa 2.5', 5' and 24' wiring harness for the front and rear of your truck
EX8000 $ 599.99
EX10000 $ 649.99
EX12000 $ 699.99
Viper Max Series
COMPONENTS INCLUDED •Wireless Remote Switch
•11' Cabled Remote Switch
•Steel Cable is 94'by 3/8" diameter (16,500 steel cable is 87' x 1/2")
•Roller Fairlead
•8T Snatch Block
•Damper Blanket
•Large Clevis Hook
•Non-Integrated Contactor
•Handsaver Strap
•1 Year Warranty
NON-INTEGRATED SOLENOID/CONTACTOR•Installation flexibility for use with the widest range of vehicles
•Install the contactor on the winch itself, or if your winch space is tight, you
can run the power cables to any other location on your truck
•Reduces the weight when transferring the winch to the front or back of your
truck
DAMPER BLANKET•Greatly reduces the danger of recoil should your winch cable snaps
•Slides up and down the line to make sure the cable drops to the ground if it
should break
•Minimizes the risk of great damage to you and your vehicle
®-Blue SYNTHETIC CABLE UPGRADE AVAILABLE FOR ADDITIONAL CHARGE
•Includes hawse fairlead instead of the standard roller fairlead
•100' x 5/16" diameter or 85' x 3/8" diameter
•Max load rating of 13,000 to 20,000 lbs
•No recoil - VERY SAFE!
•Easy to use
2" RECEIVER CRADLE AVAILABLE (not available with 16,500 yet)
o a 2.5', 5' and 24' wiring harness for the front and rear of your truck
MX9500 $ 349.99
MX1200 $ 379.00
MX1650 $ 549.00
Classic Winch
COMPONENTS INCLUDED
•Steel Cable is 94' by 3/8" diameter
•Roller Fairlead
•Large Clevis Hook
•Handsaver Strap
•Height of winch including the contactor: 10"
•6 Month Warranty
•Easy installation - no need to find a place to mount the contactor
•All-in-one setup, easy to install on a receiver mount for multiple uses
•Easy to use
•Add the 2" Receiver Cradle for extra flexibility.
VX10000 $ 339.99
VX12000 $ 369.99
Accessories
Amsteel Synthetic Winch Rope 3/8" X 85' $ 220.00
Amsteel Synthetic Winch rope 5/16" X 100' $200.00
Quick Connect 2.5' & 5' $ 69.99
Quick Connect 2.5' & 24' $ 109.99
Quick Connect 2.5', 5' & 24' $ 149.99
Receiver Cradle $79.99
COMPONENTS INCLUDED
•Hawse Fairlead
•Large Clevis Hook
•Handsaver Strap
•8T Snatch Block
•2 Year Warranty
•Easy to use
EX8000 $ 599.99
EX10000 $ 649.99
EX12000 $ 699.99
Viper Max Series
•Roller Fairlead
•8T Snatch Block
•Damper Blanket
•Large Clevis Hook
•Handsaver Strap
•1 Year Warranty
truck
should break
•Easy to use
MX9500 $ 349.99
MX1200 $ 379.00
MX1650 $ 549.00
Classic Winch
COMPONENTS INCLUDED
•Roller Fairlead
•Large Clevis Hook
•Handsaver Strap
•6 Month Warranty
•Easy to use
VX10000 $ 339.99
VX12000 $ 369.99
Accessories
They sure look good. And that price is sure competitive with the other makes. Could be a great product, time will tell. :)
