Very nice find indeed, interior looks really clean. Nice set up too.
Also replaced PCV valve. A little discrepancy on the part number but both seemed to check out. Original was 12204-30830 but when ordered 30810 also said fit an '09. New one didn't have green.
Just FYI, the PCV valve you removed (38030) is incorrect for your LC - it is for Sequoia and Tundra with Flex-Fuel engines (PCV Valve - Toyota (12204-38030) | Toyota Parts). Good thing you replaced it
HTH
In case you are OCD like me, I couldnt find the part number for that clip, but part # 61617-42040 works as a replacement
I'm a bit biased, but I like it!
Did you do anything to the headlight bulbs?
Thanks! Admittedly yours prompted me to go this route. Our 470 was grey so was wanting a silver one, but that would just be stalking.
Many of us LX owners had had success with Hikari LEDS - Headlight Retrofit for 2008 - 2011 LX570
Hah, we traded colors. My LX470 was white. With proper 305 ground pounders as well. Yes 305 is proper, love the extra width.
After AHC lift wanted to put in spacers in the rear. Installed 30mm spacers today. Grabbed these Dobinson's off of Amazon. Haven't looked at pressure readings yet, just happy to get something done in a small window of free time. Removed sway bar link and sway bar bracket, also lower shock. Still needed spring compressors for passenger side. Driver side sagged enough so didn't need compressors.
