| 10/27/20 | | 1 | Power steering service & flush. | |
| 10/27/20 | | 1.5 | M1 ATF PS | |
| 10/26/20 | | 1 | Reservoir CLN | |
| 10/26/20 | | 1 | Return hose 03-07 | |
| 10/26/20 | | 1 | Idle up control vacuum hoses 06-07 | 17030-50150 06-07 |
| 10/26/20 | | | Drive belt & pulleys R&R | |
| 10/26/20 | | 1 | Drive belt R&R | |
| 10/26/20 | | 1 | Idler OEM, R&R (27 ft.-lbf) | |
| 10/26/20 | | 1 | Tensioner, Bearing only 27 ft.-lbf | |
| 10/28/20 | | | Coolant Service | |
| 10/24/20 | | 1 | Radiator Cleaning fins, all 3 | |
| 10/26/20 | | 1 | Coolant flush (block 9 ft.-lbf) | |
| 10/27/20 | | 2 | Heater Tees 2 | |
| 10/27/20 | | 1 | Hose #1 Water bypass & clamps | Plus cust clamps |
| 10/26/20 | | 1 | Thermostat | |
| 10/26/20 | | 1 | Thermostat Gasket 13ft-lbf | |
| 10/26/20 | | 1 | Radiator Cap | |
| 10/27/20 | | 4 | Coolant | |
| 10/26/20 | | 1 | Water inlet R&I | Leak at O-ring |
| 10/26/20 | | 1 | O-ring water Inlet/Bypass joint | Bypass has some minor pitting |
| 10/26/20 | | 1 | 1282B FIPG | |
| 10/26/20 | | 1 | Minor tune | |
| 10/27/20 | | 1 | Throttle body CLN | 0.3 |
| 10/26/20 | | 1 | MAF sensor CLN | 0.1 |
| 10/26/20 | | 1 | Battery post CLN & Grease | 0.1 |
| 10/26/20 | | 1 | PCV hose PS OEM 02.00-07 | 12262-50080 PS 00-07 |
| 10/26/20 | | 1 | PCV hose DS OEM 06-07 | 12261-50070 DS 05- |
| 10/26/20 | | 1 | Air filter | 0.1 |
| 10/26/20 | | 8 | Spark plugs (I use 18ft-lbf denso max. OEM 13 ft.) | 1 |
| 10/26/20 | | 8 | Denso coil kits (bools & seals) (66 in-lbf) | 1 |
| 10/26/20 | | 1 | Head cover PS & DS bolt re torque (53 in-lbf) | 1 |
| 10/26/20 | | 1 | Oil & Filter | |
| 10/26/20 | | 1 | Oil drain, no tool plug | Install no tool drain plug |
| 10/26/20 | | 7 | Oil | M1 5W-30 |
| 10/26/20 | | 1 | Filter | M1 209 / OEM |
| 10/27/20 | | 1 | Propeller shaft & spider lube | |
| 10/27/20 | | 0.5 | Grease MI tube | |
| 10/27/20 | | 1 | Brake masker, Control wire clean & Dielectic | Boot #1 |
| 10/27/20 | | 1 | Brake system flush | |
| 10/27/20 | | 8 | OEM Toyota brake fluid 12oz | |
| 10/27/20 | | 2 | Bleeder caps OEM 8ft-lbf | Rears only, frts okay |
| 10/27/20 | | 0.1 | Brake cleaner & penetrating oil | |
| 10/27/20 | | 1 | AHC Flush 6.9+/-0.5 MPa Front. 5.6-6.7 MPa Rear. F19.75 R20.50". FRT adj Slide center 5.5mm from bottom. Turnbuckles 32-35 mm spread. | Start: F6.7, R6.2, 10.5/ End:F6.9Mpa, R6.2Mpa, 10.5Mpa |
| 10/27/20 | | 3 | AHC fluid 3qt | OEM |
| 10/27/20 | | 5 | Bleeder cap (Globe73in-lbf, Accumulator 61in-lbf)) | |
| 10/27/20 | | 1 | Torsion bar Adjust | FL 19 1/4 2CW, FR 19 1/4 1/4CCW, RL 19 3/4, RR 19 3/4. |
| 10/23/20 | | 1 | Inspect, Pull shielding, CLN engine, undercarriage | |
| 10/28/20 | | 2 | Bolts undershield | Restore RH FRT & LH #1 to #2 threads |
| 10/27/20 | | 1 | Re-attach rev mirror | |
| 10/26/20 | | 0.5 | Washer fluid | |
| | | Additional | recommendations |
| | | Recommendations: | |
| 10/27/20 | | Coil springs rear weak. Rear AHC pressure at ~6.2.Mpa. Whereas that is not bad and within range. l would like to see closer to 5.6Mpa.The lower the pressure the less AHC need to carry. One way to reduce pressure is to lower the rear, putting more weight on rear coils springs. Thus reducing load on AHC (reduces pressure). This has already been done prior to this service call. I found the rear is sitting 3/4" low. This was likely accomplish by someone adjusting the rear AHC height sensor. The front is also low by 1/2". Again likely the front height adjustors moved. So the vehicle is now sitting with only 1/2" rake. 1/2" is okay, but 3/4" is the goal. Rake or lower front than rear, help vehicle track straight while driving. HWY is when most noticeable, as streeing wonders. Reducing load on AHC, saves for when needed for loaded vehicle damping, and adds years to globes. | Replace coils spring, and add 30mm spacers. W/O spacer, if would like to keep current lowered profile? | |
| 9/22/20 | | | Re clamp FDS boots inner small RH. Sung LH & RH out large | Best done during wheel bearing service |
| 10/28/20 | | | Wheel bearing service | Due every 30K miles. |
| 10/28/20 | | | Lubes & Oils, Best all done as base line. Transmission included. Transmission is low if never set, SEE TSB. | PM |
| 10/26/24 | | | Coolant contaminate, black material on bottom of cap | BG flush when R&R water pump in 2 yrs. 2022 when T-belt due |
| 10/26/20 | | | Coolant fan shroud lower hose mount busted | Next time shroud out restore |
| 10/26/20 | | | Time belt cover, missing wire block mount bracket | Install |
| 10/26/20 | | | Wires routed wrong, to Cam sensor & oil sending unit | Reroute next T-belt service or sooner |
| 10/27/20 | | | Brake fluid was dirty (green and dark), Flushed with Toyota Fluid | Watch color of fluid in brake reservoir. We want to know how long it takes to drank and how much it darkens. |
| 9/22/20 | | | Tele steering column Inop | Repair |
| 9/22/20 | | | Window master switch. RR window broken but works | R&R |
| 9/22/20 | | | Glove box Air bag sensor housing busted | R&R |
| | | Hood struts shot | R&R |
| 9/22/20 | | | Notes | |
| 9/22/20 | | 10/27/20 | Brakes master pedal pumps / motor run time | 28 pumps/ 33.79 sec |
| 9/22/20 | | | Brake pads frt mm, rear mm | |
| 9/22/20 | | 10/28/20 | Brake control wire | corroded. CLN w/spray & coated w/Dielectic |
| 9/22/20 | | 10/28/20 | Fluid condition | DARK. CLR after flusk @ 130K |
| 9/22/20 | | | Gas cap area | CLN |
| 9/22/20 | | 10/1/20 | ECT / OAT | 192-199F w/OAT 79 IAT ~120F. After Coolant service & tune 187F-190 OAT 50F IAT ~60F |
| 9/22/20 | | | LT FT | 9-2020 BK1 0-6.2, BK2 1.6-6.2. 10/2020 ------ |
| 9/22/20 | | | ST FT | |
| 10/26/20 | | | A.I. fan shuts DN nicely | |
| 10/26/20 | | | AHC res 10+ graduations | |
| 9/22/20 | | Resolved | Observation | Condition |
| 10/26/20 | | 10/26/20 | Coolant leak water intel O-ring | R&R O-ring |
| 10/26/20 | | 10/26/20 | Coolant water cap & inlet nuts & bolts found very over torqued. | Recondition nut threads. They are stretched. |
| 10/26/20 | | 10/26/20 | Serp belt longer than OEM | R&R |
| 9/22/20 | | 10/24/20 | Acid all over engine bay front & LH side | Clean engine bay using lots of baking soda |
| 9/22/20 | | 10/26/20 | Air filter seal damage | Set straight, but needs replacing. |
| 9/22/20 | | 10/26/20 | Coolant service | Full w/rad CLN & tees |
| 9/22/20 | | 10/27/20 | Brake flush | Fluid dark. Need to see if darkens soon after flush |
| 9/22/20 | | 10/27/20 | OF&L | Maintenance light on. |
| 9/22/20 | | | Mirror rear view center, loose. | |
| 9/22/20 | | 10/26/20 | Tune w/SP & Coil boots if not done.. | Includes head cover retorque and vacuum lines. Found plugs to be factory and 3 walking-out, all loose. |
| 9/22/20 | | 10/27/20 | Power steering service | Includes CLN reservoir |
| 9/22/20 | | 10/27/20 | Steering rack LH output boot wet. Cleaned, may be spillage. | Watch, 10/27/20 looks dry, keep eye on |
| 9/22/20 | | 10/27/20 | Shock RF weep. Very minor | Watch, 10/27/20 looks dry, keep eye on |
