Flushing will likely clear up. Keep in mind Toyota came out with an additional TSB on level. They found the level to low. We now use low temp range to set level.
T-SB-0129-08 July 9, 2008
Automatic Transmission/Transaxle Fluid Level Inspection
Temperature Ranges
For vehicles equipped with a transmission requiring the use of the overflow type automatic
transmission fluid (ATF) inspection process, the ATF must be within a specific temperature range for
accurate fluid level inspection. Inspecting the ATF outside of the specified temperature range may
result in incorrect ATF fluid levels and could lead to shift quality, M.I.L. “ON”, and/or transmission
damage issues. Please see the information in this bulletin for updated ATF level inspection
temperature ranges.
Temperature Ranges
temperature ranges.
