For Sale 2004 GX470 Houston
TX
Year
2004
  1. GX470
Mileage
180658
Color
rgb(4, 11, 85)
Outside Link
https://www.facebook.com/marketplace/item/320076503706214/?mibextid=T6ff65
I have decided to put my modified GX470 up for sell as we want to upgrade to 200 series platform. It has extensive modifications. I am listing for $27,000, or, best offer that is reasonable with all the mods. It's got 180,658 on the odometer. I've performed all the major mods most owners would like to have. All the major modifications were performed by experts at Duggys Garage in Houston. This rig is clean for an 04. It's had all major services and then some. It's solid rig with no pending maintenance for quite some time. Clean frame. Clean interior. Ice cold AC front and rear. I'm willing to meet up locally or even drive to meet someone halfway. I'm flexible. Clear TX title in hand. This is our overland rig and wasn't daily driven.
Interior
-Coverlay Dash cover (not glued in)
-LED Lighting kit from V-Leds (good kit not amazon)
-Updated Prado steering wheel
-Kenwood Excelon wireless/wired Apple car play and android auto head unit
-All new Focal Audio speakers (front component set + mid, rear 6.5 2-way with tweeter)
-New diamond stich pattern replacement leather seat covers front and rear from Ridies.com
-OrangeBoxx fab rear molle panels
-Rear power via blue seas fuse box, wired direct to battery via a breaker switch for safety using 8ga wire, with additional slots for accessories to be wired for power
-Power panel with USB ports and 12v plug outlet connected to the rear fuse panel
Exterior/Mechanical/Maintenance
-Tandem Offroad 612 wheel in Bronze
-Kenda Klever R/T 35x10.50 tires (with BMC done, pinch weld flattened and sealed, and other small mods to allow the 35s to rotate with no rub)
-Speedohealer wired in to correct speedometer
-Dobinsons MRR (remote reservoir) 3 inch suspension lift with medium springs up front and HD (+600lbs) in rear
-Dobinsons front upper control arms
-New OEM Toyota lower LCAs (have 20k miles on them now)
-Dobinsons adjustable rear lower trailing arms
-Dobinsons adjustable rear upper trailing arms
-Dobinsons adjustable panhard bar
-Dobinsons snorkel
-Metaltech OPOR sliders
-SSO Hidden winch mount
-Smittybilt 10k winch with wireless/wired remote and synthetic line
-Factor55 Flatlink E
-RPM Fab dual swingout steel rear bumper
-Prinsu roof rack
-BXBuilt quad LED retrofit headlights with LED drl strip
-KC Hilites Cyclone LED lights under the hood
-KC Hilites Gravity G34 LED lights wired as fog light to factory fog light switch
-Timing belt/water pump/pulleys replaced with Aisin kit at 140k (currently sits at 180k)
-Doug Thorley Long Tube headers
-URD Y Pipe
-3 inch exhaust with magnaflow 20 inch resonator and 24 inch muffler
-BigDaddy Angled O2 bugs to prevent CAT codes
-East Coast Gear Supply Toyota 8.2 rear axle + third member purchased new, assembled (has 19k on it now) w/Eaton E locker
-Nitro 4.56 gears and all associated parts replaced when the axle was installed including servicing front diff with the new gears
-Wholesale Automatic Transmissions Nomad HD Valve Body and TCC lockup kit
-Front wheel bearings/hub assembly replaced with OEM at 140k
-Rear OEM wheel bearings and hubs when the new axle was installed in 2019 at 160k miles
-Rear rotors and calipers done with the rear axle
-RR Racing Wilwood 6 piston front big brake kit with upgraded lines
-Dirty Deeds 12 hole injectors upgrade
-CVJ Toyota Reman axles with high clearance extended red boots
-New 555 inner and outer tie rods
-Replaced PCV valve 20k ago
-New power steering reservoir with new fluid (flushed)
-Full transmission fluid replaced with Toyota WS about 1k miles ago (second time its been done since 132k)
-Larger transmission cooler with Mountain Passes Offroad mounting system
-New Optima Yellowtop 27F AGM
-Voltage Booster Pro "Texas Slim" for GX470
-Valve cover gaskets replaced at 145k
-New MAF sensor
-New Denso spark plugs
-New Denso ignition coil packs
-New OE tensioner
-New OE alternator
-New OE Denso AC compressor
-New oil and filter (M1 full synthetic high mileage 5w30)
-Cabin AC servos replaced (all the temp control and air mix servos)
