Need some advice….
My 2001 with 215k miles has had an oil leak for the last several years. Bad enough to leave a few drops on the pavement every couple of days but not bad enough to have to top off when I check the oil periodically. I’ve had the front crank seal replaced but it did not fix the leak. It’s definitely coming from behind the timing cover. (Maybe oil pump o ring?) The Toyota/lexus specialized shop I use said “upper oil pan has bolt that is cross threaded into oil pump leaking” and the engine would need to be pulled out to fix it. So two separate leaks. They brought up the Option of putting a newer used motor in it as well. I am not a handy guy so I am trying to figure out what to do. Pulling the motor or replacing the engine would cost a crazy amount of money for sure. I’ve been putting it off for a while but I can tell there is oil that is starting to collect on the left steering rack boot (rack was replaced less than 20k miles ago) which will eventually cause that to go bad. It’s also probably getting on the timing belt too which could cause early failure.
