Hey everyone! I’m new to the community and hoping to get some guidance from those with more 2UZ-FE experience than me.
I have a 2000 Lexus LX470. The truck had been running perfectly with no prior drivability issues, no check engine lights, no rough idle, nothing abnormal.
About a month ago, I had the timing belt and water pump service done at a Toyota dealership. After picking it up, I drove it home with no issues and then it sat for about 2–3 weeks since I don’t drive it very often.
When I started driving it again, I began experiencing sudden stalls while driving. It would shut off unexpectedly, but would crank right back up immediately. This happened maybe 3–5 times over a few drives.
It progressively got worse to the point where now the engine will crank, sometimes briefly start and rev, then shut off immediately. At this point it will not stay running and had to be towed.
Additional details:
No previous history of stalling before timing belt service
Has anyone experienced something similar after a timing belt job on the 2UZ-FE?
I’m open to the possibility of coincidence (fuel pump, crank sensor, etc.), but the timing of the issue makes me want to rule out anything related to that service area first.
Any guidance on where to start diagnosing would be greatly appreciated. I’m trying to approach this logically before throwing parts at it.
Thanks in advance!
Additional details:
- No warning lights prior to the issue
- It almost feels like someone is turning the key off when it stalls
- Battery has since weakened from repeated start attempts
- I did notice one small vacuum/PCV-type hose that seemed loose and slightly oily near the intake area
- No visible coolant or oil leaks
- Oil and coolant levels are full
Thanks in advance!
