A friendly warning to any 2000my Land cruiser owners. I've done alot of reading, searching, and investigating on this problem. My LC just dumped its tranny at 90k. I've heard of alot of other 2k 100's also dumping their trans around this time frame.
I was one of those people who had warning signs and didn't follow them so learn from my very expensive mistake.
If your trans is making any noise in Overdrive and the sound disappears when you turn the overdrive off....see a tranny shop. If I had gone to a tranny shop before my catastrophic failure, things might be costing alot less. Heed any warning signs or funny noises in any 2000my LC transmission. A tranny shop can isolate and replace the defective parts before they break and grenade your trans. This is a known issue and OEM Toyota Rebuilt transmissions have these weak parts improved.
A stealership will not rebuild your trans, a trans shop will. A trans shop will also warranty their work and the parts installed.
The original quote was over $4000.00. I'm gonna pay alot less because I'm a "Negotiator"!....mind your 2k LC tranny...if it talks, listen, and fix as a preventative measure. There is also a TSB about this issue.
Much respect,
Mike.
Much respect,
Mike.
