2000 flasher relay location? - LS430 RETRO
anyone know where the flasher relay is on a 2000 and how to get to it? I tried to look near the driverside fuse block and couldn't find it.
by the way, this is what I've been working on:
I'm finally starting on this after years of searching for a housing and trying to figure out what I wanted to do. I finally found that the headlights from the 2007 land cruiser will fit on the earlier ones with a new grill and valence panel. I figured this was the easiest housing to retro because the high and low beams were in seperate reflectors, instead of the pre-07 where the bulbs are above each other in the same reflector. So, after ordering those parts, I've finally started!!
obviously I'm going to be using ls430's. I've opted to do a tsx clear lense swap. I'm using one spacer, which gives the cutoff a little more plue/purple, and makes it extremely noticably sharper.
For the led's I'm using 52 amber superflux leds at about 60mA's for marker/turns. I'm going to drive the led's with an opti-drive pwm. Led boards are covered with aluminum tape, which was a HUGE pain to cut out the led locations. They'll be potted before I put them in the headlight. There are 20 led's in 2 colums pointing forward, and 32 pointing outward.
I will also probably be retroing in some tsx projectors as fog lights as well, but I'll do that after the headlights are done.
CUT OFF PICS!!!
This picture is with the led's at full brightness, so parking lights would be dimmer, but you get the idea...
CUT OFF PICS!!!
's 06 hundy....
