2000 4Runner sr5 4wd bad positive camber
arizona
Alright all you 4Runner enthusiasts. I installed a rough country 2.5 inch lift a little over a year ago. I ended up struggling with bad camber. I maxed it out and still has tremendous positive camber so I installed a diff drop, built cv axles for a lift, new tie rods, lifted control arms for 2-4 inch lifts, adjustable rear control arms, adjustable rear track bar, and even tried my luck with wheel spacers (thinking it would put more weight in the center of the car to even it out. I took it to an alignment shop and they said they did everything they can do to fix it and I still burn through sets of tires in a matter of a few months. Does anyone have any ideas on anything else I can do or am doing wrong? Cause I put a lot of research into lifting before I did and even afterwards to figure what’s wrong and feel I’ve done everything to fix it aside from adjustable ucas but I have been doing my best to avoid anymore money in this thing at the moment not to mention the wear is worse on the driver side so I feel it may be something entirely unrelated. Thank you for your time
