Is anyone running anything smaller than the stock 18's on the 200 to accommodate a thicker tire wall for a softer ride? Not looking to offroad, but would like to further soften the already amazing ride! Cheers
Looks sweet! How is the road noise at highway speeds?Currently running Icon Six Speed wheels that are 17”. I prefer the look of the balloon tire with the smaller wheel as well as the ride quality. Seems to soak up the bumps nicely when they are set about 38psi. View attachment 1939089
Would you mind posting a picture of your truck?@Noodleman If you are in this for ride comfort make sure whatever size wheel you run you can get an appropriate NON-LT tire for it. Any LT tire, from C-load up to E-load requires roughly 10psi more than a non-LT tire, and this has a dramatic effect on ride quality. Tire weight does too.. LT-C rated will be marginally heavier than your stock p-metric.. an E-rated will be dramatically so.
Keeping all of this in mind, but still wanting a decent all-terrain tire, I went with the 17" TRD rock warriors and toyo open country ATII in P285/70R17 and am very happy with them, including ride quality. 13# lighter per corner than my old e-rated 18" KO2s, 10psi less required.. basically similar weight and pressure to stock landcruiser tires.. and they look fantastic. Time will tell if they hold up to my use.. but it's pretty mild compared to some on this board.
Tad, I have looked at your truck tons of times on the forum and love your setup. You still running with the stock height or did you add spacers to the front? Looking at doing something similar with BFG AT KO2's. I too want to run the DakarZero wheels but the price and long lead time has me thinking about the newer Method 313. Not a lot of options out there in 17's with minimal offset and a preference of hub centric.
Yeah, I called them this afternoon. No black versions in stock. Deciding between waiting or going with another option. First world decisions....Yep, I’m still stock height. May want to see what MLO has in stock because they usually order a few extra sets when they get a container.
