Simple fix is a convection type heater.
I don't even drain coolant.
14mm deep socket to remove block drain plug, install the supplied adapter to 5/8" heater hose, this is supply for convection heater. Use the supplied "Y" to tie into the 5/8" hose to heater control valve on fire wall.
Your block drain is via skirting at shock tower behind the left tire(remove tire)
Keep heater low, wrap or isolate/insulate any spots where hose could rub.
this is a 10minuite job on the 1HZ or 1HDT. For a FZJ80 delete the PHH and extended the hose to water control water valve as above.
This system offers 1/4 heat on gauge at start up, sometimes a slight defrost of windshield.
Best to select Defrost on dash when plugged in. BTW everything is included in the kit, power is short but you can fix that!
The key is pick up coolant from as low as possible, send up to firewall control valve area as vertical as possible this ensures convection.
