1htd with 5 speed
Here is the final confirmation of what I have put together for my 1HD-FT to H55F setup. I went with the 300mm versions of the clutch and flywheel assembly.
  • H55F = 33030-60450 from LHM Toyota
  • H55F 21 Spline Input Shaft = 33311-60170 from LHM Toyota
  • H55F Shifter Assembly = 33530-60220 from LHM Toyota
  • 1HZ to H55 Bell housing = 31111-60230 from LHM Toyota
  • Clutch Fork = 31204-36110 from LHM Toyota
  • Clutch Fork Boot = 31126-60070 from LHM Toyota
  • Clutch Slave / Release Cylinder = 31470-60161 from LHM Toyota
  • Pilot Bearing = 90363-15017 from LHM Toyota
  • Thrust Bearing = 31230-60130 from LHM Toyota
  • 300mm 1HD-T Flywheel = 13405-17020 from Akella
  • 300mm Pressure Plate = 31210-60122 from LHM Toyota
  • 300mm 21 Spline Clutch Disk = Exedy NCD 34461 from Phoenix Friction
:cheers:
Steve
Helped me to do my 1HD-T swap into my 75 ser Troopy.
CAN I MATE A H55F TO A 1HTD
THANKS
Where did the H55f come from?
I think the easiest way is to use a 1HZ H55f box and clutch, which is slightly smaller than the 1HD T clutch. Some have used an Isuzu clutch with this gearbox to get the full size clutch diameter.
