Hi troops.
So I reciently had a new injector pump fitted and have since had a problem at idle and crawl.
1994 GXL 1HDT, Automatic, GTurbo grunter, front mount intercooler.
New injector pump and injectors.
The old girl runs sensational at wot, but has a low-idle/low-rev issue. She starts idling terribly, like its running on a few cylinders, or is starving for fuel, at low idle, ie. with foot on brake at lights when in Drive (around 900 rpm) or idling through a car park. Goes away immediately if I put it in park or neutral, and turning off the aircon tends to fix it as well. That’s with the idle set at around 950 which seems too height – feels like it’s trying to pull away. That almost seems like part of the issue, it’s trying to pull away, but my foots on the brake, like in a manual when you don’t give enough fuel on take-off and start bunnyhoping. If I slightly tap the throttle it goes away, but then returns to a ‘chugging’ idle, which naturally I don’t let persist and its awful. To avoid the problem, I have to flick it into neutral anytime I’m coming to a halt.
When I got the new injector pump, it was setup for a manual.
Now the major question are:
1. What do others Auto 80s idle at?
2. Has anyone else had this problem and solved it?
3. Is there a difference between the manual and automatic 1HDT injector pumps that may be causing this issue?
I live very remote, so I brought the pump exchange. The pump builder has offered to rebuild mine and swap them over, but the logistics are a nightmare.
Any thoughts or advise would be greatly appreciated.
Cheers all !
Cheers all !
