Thanks for confirming that while my head is full of mostly useless info, occasionally some if it is useful . . . .
hopefully
hopefully
Yes, I mentioned that I have the GTurbo Bad Boy and big FMIC.Did Mick tune the pump to suit the turbo and intercooler?
21 fine splines for H150, same as the R151F? I thought the H150 only come with 14 coarser splines.300mm disc with 21 fine splines for H150
H151 has 14 coarse spline thick input shaft
H150 has 21 fine spline and thinner input shaft
R151 also has 21 spline and I think a different shaft diameter
Well, I have checked the parts program for the VIN# coming of a 1997 HDJ80 (24 valve 1HD-FT) and for a 1993 HDJ80 (12 valve 1HD-T). Apparently both have the H151 box. If so, what is the application for the H150?
If you have a HZJ105 STD you need a h150 box and transfer from a 78 or 79.
The HZJ80 (1HZ) has a fine spline H150f.
The HDJ78/9 has the coarse spline H150f. (Direct fit)
The FZJ78/9 also has the coarse spline H150f. (Need 1hd bellhousing)
The VDJ76/8/9 has the H150f/H152f but needs the 1hd bellhousing and input shaft.
A GCC spec GRJ79 will also have the H150f box but expect the same as with the VDJ series, needing bellhousing and input from 1hd series.
So why can’t you get an 80 series box and use your transfer case?
If the HZJ105 had the R151 box, then he would need to swap the transfer case input gear to suit the larger H15# gearbox output shaft.
