Assuming you're running additive. After warming up to operating temp (usually 76C) then parking, my coolant temp gauge will read 20C after 2 hours. So after 7 hours of daylight sun, it might keep above -5C? When my coolant temp dips below -5, I know it will be a hard start (on 12V). Also, if you're running a catch can, I've found frozen water from vapor. That may contribute as well? Especially if there's no pressure relief....
Diesel heaters are expensive toys. Couldn't survive winter without one though. The whole engine is heated, including oil and tranny (if you point the exhaust correctly). My coolant will read +35C in under 40 mins at -25C. Will heat to +45C in an hour. And you can heat rum on it too!
