So, I've had a Madman EMS1 for a number of months now.
I bought it to get an EGT gauge, and put two temp gauges all displayed on one device. It allowed for a fourth metric to be displayed: pressure. Originally I had this slated to read fuel pressure to indicate whether my veggie oil fuel was clogging filters. That system seems to be running very well thanks to meticulous pre-filtering. So, with a growing interest in turbos, I decided to hook it up to dead turbo boost pressure.
I took the hose off the crossover pipe and put a 3/16th vacuum tee and 3/16th hose back to the crossover pipe and then off to the pressure transducer. I put a 3/16 hose Barb on the transducer and solderd a ground wire on that brass fitting. Then ran the appropriate wire from the ems1 to the sender.
At hard acceleration it climbed up to 12lbs boost.
Around town I often saw 0lbs boost.
I have a manual boost controller on the way for the extra 2lbs of boost I can push out of the stock turbo.
