I will check and see if fastenal is shipping there.How much for the block shipped to va 20151?
How much is shipping for the oil cooler to 78750?I am selling a 1fzfe engine that was pulled because the PO said it spun a bearing. I kept it around for parts but no longer need it. It is was mostly complete before I started parting it out. Located in Northern New Mexico.
I will list out some of the simple stuff but if you don't see something in the pile just ask.
Prices don't include shipping, buyer pays shipping.
Stripped block I may scrap the block to make room if there are no takers. 50.00
Upper Aluminum oil pan 50.00
Lower steel oil pan 20.00
SOLD Head 50.00
SOLD Cams 40.00 each
SOLD Valve cover 50.00
Pistons and rocker arms 50.00
Crank 60.00
Crank pully 35.00
Oil cooler and cover 40.00
Timing cover 40.00
Timing gear chain guides set 35.00
Alternator 35.00
Water pump 25.00
Power steering pump 35.00
Power steering pump resevior 20.00
AC compressor 60.00
Upper and lower intake manifold 60.00
Throttle body 45.00
6 injectors but one has a cracked plastic housing40.00 for all.
Manifold shields - scrapped
I think so I will check
do you have the power steering reservoir?
Thanks!
Yes I believe I do.Do you still have the power steering pump?
When I acquired the 80 that this was in it was not running. The engine spun a bearing. Supposedly it had been running fine before but I honestly cannot confirm that. It may be fine but I have it priced more as a rebuildable core.If it was working well when it was still in the vehicle I'd like to get it. Could you price shipping to 29067?
