Thanks for your concern guys but like j said its all good. I am in front of it and can make an educated guess.. Won't be removing sump, accessories and timing cover to cahnge it. The chain does not run on the top of the guide where it has broken. When it is all back together the chain will put tension on the guide in a lower spot and there will be no issue..I wouldn't lightly dismiss anything @landtank points out. He has a lot of experience and you may too. You also have the advantage that the parts are sitting in front of you instead of the rest of us looking at a picture, but Landtank knows his stuff. Not trying to be contrary or anything, just wouldn't want you to button everything back up and later have problems from something you could deal with while you have things accessible.
Missing piece is in the bin..I am no expert, but the part that would concern me is "where is the missing piece?" I would be worried that it could have dropped down into the lower gears and damaged them causing a timing chain failure later. It may just be in the oil pan somewhere but I remember a thread of a guy getting stranded for a while in panamint valley with a timing chain failure from a bolt that had caused the chain to break and damaged some teeth on the lower gears. Maybe me landcruiser over analyze/be ready for anything tendencies are showing through.
HELP PLEASE! I'm stuck in the wilderness with a dead fxj80
It will survive. Just the top.
It's back together and running... And guess what genius it's fine... Wow amazing isn't it... So explain to me exactly why it wouldn't of worked it why in the future it will break.. The chain does not even touch the top of the guide. This is a breakdown repair that needs to get up and going again and I wasn't going to waste another 8 fxxxing hours pulling sumps and covers off..Ah, no. "Just the top of my head is missing but my hat will cover it just fine."
Putting that engine back together as it now sits is exactly like taking a shower and putting your dirty shorts back on......
I not once asked for help just wanted to show what I was up to at the shopYou sould try pirate. Friendly blokes over there
Folks were just trying to help since you didnt say the project was already back togerher again and runnig when posting pic of an open head.
Hey reconwhatever may be I have a little knowledge to.. Never asked for there Input not once...mmmmmm makes me wonder what you guys actually do on this forum.. Just wait for people to post then it starts hey????Hey genius, between Cdan and Landtank, that is eons of knowledge base. I wouldn't be so prissy nor discount what they say.
