1FZ rebuild time!
The woods
I’m just gonna post a few pics of this engine rebuild that my buddy sent me tonight. Getting the pulley off didn’t go so well. I’ve never seen him have so much trouble with a crank pulley.
After the last gigantic cheater setup, he got it. Apparently, the bolt was absolutely slathered in red Loctite. Did Toyota do that? More pictures will come as he gets things further apart.
Jus did one of those crank pulley bolts that was crazy tight. Had to heat Locktited bolt to over 500 degrees at the head to get sealant on threaded end to release. It was a dealer rebuild!
Ah, maybe that’s the deal. I’ve never seen anything with that much loctite on it.
As for the size of the breaker bar, I can’t be there for the rebuild, so my mechanic friend is handling the whole thing, and he weighs about 125 # soaking wet! That means that a 17’ cheater is necessary.... I, on the other hand, make some GREAT ballast!
Damn...THAT'S a cheater!
Hope he didn't turn the world off its axis a couple of degrees when using that thing.
This is a case where a torque multiplier would come in very handy. After working on large diesel trucks, and other equipment that had lots of high torque fasteners a torque multiplier is a real time saver.
I use a CDI, DPT 1200 torque multiplier, due to it's compact size it works in confined spaces where you can't fit or swing a long torque wrench.
With it i only have to input 15 FT pounds of torque with the multiplier crank handle, (that's the screwdriver looking thing in the photo below) and i can get up to 1200 FT pounds of output torque.
At my age I've found it's MUCH better to work smarter, not harder.
