1FZ-FE York installation fail
New Jersey
Website
www.sdsysdesign.com
Soon after I picked up my LX450 Creampuff, I started figuring out an OBA system similar to what I have on the 91. I put a feeler out for the York kit and picked one up from a mud member who was doing an engine swap or some such nonsense.
In any case the kit and York have been sitting in my basement for over a year and I had some time today to try to get it all together.
The bracket bolted to the side of the motor without much issue and the new 3 groove water pump pulley fit perfectly and was machined quite nicely. That's about all the good stuff.
All the belts line up perfectly, but the York belt fouls on a coolant line that runs in front of the valve cover. The belt included with the kit is too long.
The York compressor is seized.
Sooooooo...long story short, I put it all back to stock, filled up some spilled coolant, took the time to add some foam tape to the fan shroud to get a better seal on the radiator, and buttoned it all back up.
Needless to say I'm more than a little disappointed and was wondering if anyone else who has this kit ran into difficulties during the installation.
The York can most likely be salvaged or easily replaced, and the correct belt can be sourced, but the bracket itself doesn't seem to be made properly.
I am very sad.
Which bracket is it? Is it the one from the GroupBuy I did like 5 years ago? That one, IIRC, required a tiny bit of hole elongation to get everything to align correctly. Other than that it fit perfectly. I never got mine fully functional because I bought my SC a few days later and 86'd the York.
Honestly I don't know which bracket it is, but it is very well built and thought out. It cradles the York on 3 sides and is very stout. The original was sold as a kit with the machined aluminum water pump pulley, the mounting bracket and tensioner pulley, and a belt. It all looks great, but I would need to push everything forward at least 1/4" to be able to clear that coolant line. There is no play in the bracket mounts. I would have to have them machined out significantly.
Sounds like the kit I offered with the help of GLWJ. It was very very similar to the kit offered thru Slee many moons ago. I remember having to machine it but it wasn't considerable and it was just one hole from what I recall. Its been a really long time though so I could be off. Can you send pics of it? Maybe it will jog something.
I'm trying to find the original thread but it may have been purged because I can't find it anywhere using search.
Pictures for your amusement.
Hmm, I wonder if that is the Tim Korn/Stainless Doctor kit. It seems a little different of a design then the GLWJ one I did the GB with. I did not have that hose interaction issue.
Looks like that could be resolved with a custom hard line to replace the one that is there. Duplicate the rest of the line with some steel tubing and several bends, then put a new 90 bend on it at the end of it and use a small straight hose instead of the 90 degree one. It's kind of a long hard line and would be tedious to do, but with a decent tube bender and some time could fix it right up.
Here's another photo angle on it, the 90 degree hose of issue. If you extended the hard line out farther and made the 90 in the hard line, you'd not need the hose or clamp up there in the way of your belt. Or you could replace it with hose all the way and just route it some other way.
I'll say it, this is what you get for straying from the 3FE! :flipoff2:
So do all these kits mount the York from all 3 sides?
It's the only style I've ever seen and likely for good reason.
Not really. I built a bracket from scratch to run a York in my Piggy. Mounted one side only. Used 4 grade 8 bolts, maybe 1/4 or 3/8" to mount the York. Never failed in about 15 years of heavy use.
I tried to remove a York compressor from a Semi in a You-Pull scrap lot here in Flat Rock, MI.
The threads were toast from corrosion. Dust actually... It fell off when I loosened the bolts.
The mount for the Semi only had it bolted in on 1 side.
I think there are holes on all sides to help make it easy to install for a variety of applications/uses.
I found some rebuilt Yorks on Ebay and I might just start with that than try to recondition something else for my truck...
Bummer the kit didn't work on the 1FZ
