1FZ-fe replacement exhaust
Difficult to get decent pics without putting her on a lift and removing skids. Basically out of the Magnaflow cat, up and over the frame to the muffler.
Out of the muffler, following the OEM path, over the right rear frame rail and exit just shy of the bottom of the frame.
Cat skid plate.
That looks great, thanks for taking the time to take and post those for us. Is it much louder without the final resonator (I think that's what it's called)? I like my vehicles very quiet.
Then you're going to have to spend the coin on OEM parts.
I get a low growl around 1200 rpm. My truck is not quiet on the highway, so exhaust drone is the least of my concerns.
I got a new (front to back) Manta SS 2.5 from Australia. Working well (other than have leak from stretched manifold bolt that need to Helicoil). Added a single Magnaflow cat ; seems ok. Did have to get bung for O2 sensors
I'm about to install mine. Any tips? I got the full kit, front to back
was my buddy welder that did it. He indicated it was a "tight" fit so just take your time.
Careful on torqing the manifold bolts (as they send new bolts instead of existing type)
I used the Magnaflow downpipes/cat, the Magnaflow muffler, and had a local hot rod shop build a custom over the frame exhaust out of T304 stainless. Exits behind the right rear tire level with the rear bumper skids.
I supplied all new OEM hardware/hangers/donuts/O2 sensors, and had the downpipes/cat ceramic coated before installation.
Passes inspection with a single cat. No issues.
This the type of language that’ll get any guy off.
