1FZ-FE Engine noise
Tukee Town, AZ
My 97 has been making a noise and I can't seem to figure out what it is...
Here is a video I took driving today, it only happens when the engine is under load, and sounds like a can of coins jingling. changes with RPM, goes away at idle.
This is someone else's video, real similar sounding noise:
Sounds like exhaust (possibly a catalytic converter plate loose) or a loose bracket on the exhaust or heat shield.
sounds like you have some gravel or debris around the heat shield in the exhaust that is rattling
and that was my initial thought too! I dug around and found nothing... but for the sake of being sure I'll give it another look. I'll take some pictures of the shields I'm checking, maybe I am stoopid and am looking in the wrong places
I had one of those rattles - my exh shields looked good, but the underside was corroded enough that it took a body washer to get the shield to compress with the 2 bolts/ea shield.
If I ever do the quality ceramic / Eastwood / whatever coat the manifolds, I’ll buy new shields & copy Joey & others with pretty 1FZ’s.
IIRC, I think I saw them FS on Wit’s End....... @NLXTACY ??????
No not on my site but maybe I should buy a batch and just ceramic coat them as a batch :hmm:
Check the heat shields on the manifold and the ones that surround the exhaust coming off of the manifold. They crack over time. Mine rattled. You can snug them up with a hose clamp.
If you did, I’d pay the surcharge for the 1-stop convenience of that alone.
I keep telling myself that’s my plan but I haven’t even ordered the tins yet.
I bet some snail kit guys would have the same thought ;)
