Sure, but on these engines, the ECU probably doesn't lean out the mixture and advance the timing during high speed cruise.
Actually it does. The ECU is designed specifically to run on gas anywhere from crap (retards the timing) to high quality (advances the timing). I think it was Brian4x4 who referenced an article where they talked about how the engine was designed to run in a wide range of scenarios, and would adjust the timing appropriately.
Which brings us to....
If the ECU detects a problem with the EGR, it sets the MIL and my guess is that it does not run lean and advance the timing. Many people here are trying to fool the ECU into thinking the EGR is working when it isn't, so this may not be a good idea. If there is no benefit in MPG (I didn't see one either) then why bother?
Untrue. The ECU will set the MIL, but it does not effect the way the engine runs. I ran for almost 1k miles with the EGR system disabled and no engine codes, same gas mileage as thousands of miles with the EGR system in perfect working order. Since the weather changed and it got cold enough that the EGR CEL is coming on....guess what? Same gas mileage.
The point of fooling the ECU is to avoid the CEL. That's the
only thing it does.
And in fact Mr. T provided a way of disabling the EGR system in the OBD-I trucks. There's an actual Toyota part that you can purchase (if you can find one, last I checked they were out in the US) that will bypass the EGR temp sensor and will preven the CEL from being thrown.
It is well documented that it decreases the combustion temperature by 300-400 degrees. This is why it reduces NOx.
In some vehicles. Not necessarily in the 1FZ.
Plenty of people drive around with plugged or disabled EGR systems (and the EGR temp sensor
not bypassed) and no CEL is thrown. Why is no CEL thrown? Because the ECU believes that the engine is in the correct operating temperature
without the EGR system active.
It is indeed our misfortune that HGs tend to fail, but why would higher combustion temperatures make this situation better?
Corrolation != Causation, so I cannot say for 100% sure that the EGR system causes it, but it's certainly likely. It could be a couple of reasons.
One possibility is the varience in temps. If cylinder 6 is running significantly cooler than cylinders 1-5, then the temp difference could cause stress that could cause it.
Someone else (Bear80) did some research and found that an engine that runs
too cool can cause something called
head gasket creep.
No doubt there are some down sides, but compared to destroying a piston from high temps or preignition, this seems like small potatoes.
Where do you get the idea that you will be running so hot that you will destroy a piston by disabling the EGR system?
The EGR system is disabled under heavy loads, accelleration, WOT, etc. In other words when the EGR system is disabled is when the engine will run it's
hottest and be under the most strain and stress.
The EGR system is only active when you are cruising, which is when the engine is under very little stress and going to be running cool. During high speed cruising you have tons of cooling (maximum air flow) and very little load so there's no heat build up. The engine doesn't
need to run cooler under those circumstances as it's already naturally running cooler than it would in comparison to driving around town, for instance.
And I have not seen a single case in the thousands and thousands of posts I've read that's indicated that the EGR system caused a piston to fail or an engine to ping. If that was the case, shouldn't we hear widespread failures from the thousands and thousands of people overseas running 80's without an EGR system?
Ebag- in the other (big) EGR thread, you stated that you weren't sure whether the EGR temp sensor mod alone will actually disable the EGR modulator, or whether one would need to block the vacuum lines, as well. In fact, you said you needed to test it out to see. What you state here makes it sound conclusive that blocked vacuum lines are needed. What happened in between? Have you done the test you talked about?
I haven't had a chance to test it yet. Blocking the vac lines works 100% for sure. I was not sure on simply disabling the temp sensor.
Yes egr will lower in-cylinder combustion temperatures and control NOx better by doing that. It also gives slightly higher gas mileage. The EGR gas itself is very hot (but much cooler than the in-cylinder combustion temps would be, so it cools in-cylinder). But being hot going in, it might cause some thermal expansion for that cylinder different than others, which just might have some gasket affect. Don't know on that. If the engine was designed with it, it is calibrated for it. If you wanted to take it off, you would need a different computer chip calibrated to not have it, basically the setup they have in other countries where it is not used. This is likely much more trouble than it is worth. Generally, I like to leave highly engineered products stock!
That is true for many vehicles with EGR systems. It is not true for the 1FZ. As I've stated, the 1FZ was designed to run and operate
without the EGR system. It does not necessarily lower temps any. You do not need a different ECU/chip to operate without it. For the ODB-I trucks Toyota provided a part that will disable the EGR temp sensor without needing to swap ECU's. I have one that's in my truck that I will be removing as this doesn't work for the OBD-II trucks.
I was under the impression that a drop in combustion chamber temperatures and the subsequent reduction in NOx levels is one of the main reasons for the EGR.
That is the reason and design. But if the engine already runs cool enough that a drop is not needed, then is the whole system needed?
The only thing exclusive to cylinder 6 with regards to the EGR is that the exhaust that is re-injected is scavenged from the exhaust manifold of cylinder 6. This scavenged gas is dumped back into the intake manifold an flows into every cylinder.
The problem with the EGR system design is that the exhaust gas gets dumped into the plenum directly over the #6 cylinder. While it's an open plenum design, the nature of it means that most (if not all) of the exhaust will go straight down the #6 cylinder.
I think the PCV system is a bigger culprit here. Put on a catch can and minimize the oil in the intake and the exhaust soot will flow right through.
I agree that the catch can is an excellent idea.
