+1If it gets hot and it’s not a TTY fastener is should get a second go around.
Why we all were sent out like Minions (little yellow cartoons) - you didn’t pack a TQ wrench, just a ball-peen hammer to smack & paintpen all that “ping” - if it fell/felt dead, it was wasn’t tight.
Lube the valve cover plug gaskets in Sil-Glide & pull / check — if you want to OC/D the ARP nuts.
But most just call ARP studs & the clamp nuts as final job unless you run a exotic headgasket / you think your crazy boost motor needs a 2nd pass. —— You know best ——
