1fz-fe compression variation question
Locked79
Ayr, QLD
Hi all.
I have a 1fz-fe on the shed floor which I am selling. The potential buyer asked for a compression test so I did one this morning. I know they are normally 170 psi or higher new and that the Min is 128 psi and max variation is 14 psi. The reading were
#1 175psi
#2 180 psi
#3 160 psi
#4 158 psi
#5 160 psi
#6 160 psi
These tests were done cold and dry. Has 380k km on the engine. Is the variation acceptable and is this a sound motor to sell?
It's a bit of an extrapolation to go from a few compression numbers to deciding whether the engine is sound or not.
The best you can do is provide the figures and let the buyer decide for himself about that bit. If everything is still readily accessible, you could do a wet test and see the difference. Easy also to do a leakdown test.
