1FZ-F GCC spec missing vacuum hose
Auburn
I seem to be missing a vacuum hose and I can't figure out where it would connect. If you look at this parts diagram you can follow my description:
Part 25860-66010, Valve Assy, Vacuum Switching No. 1, connects on the left side via a short vacuum hose to a 3 hard line manifold (part 17303-66010). The vacuum hose on the other end is missing (std part number 90999-92003); see photo. The parts diagram says that vacuum line is 390mm long. Maybe it connects somewhere under the carburetor? I can't find an unused nipple so thought I would ask if anyone had any ideas. The parts diagram doesn't show where it connects.
Truck is running fine btw. Maybe I should just leave well enough alone!
If I remember correctly, it should connect to behind the carb(engine side) there are three nipples there. Two top one bottom. I think it goes to the bottom one.
I'll take a look. Thanks.
