SOLD 1999 Lexus LX470
Status
Not open for further replies.
Denver
Year
1999
  1. 100 Series
Mileage
240968
Color
White
Littleton Colorado White LX470. Owned 4 years - nicely used but not abused! Currently at 241k. This has been a terrific truck for the family, but I just don't use it much anymore and would rather it go to someone who really is wanting one of these. This truck has never left me stranded and has been all over; Moab/Utah/Telluride/GrandCanyon/California Sequoias and beach/Las Vegas/Yellowstone and more. Awesome in all situations from running to store, to long vacations, to hauling wood from HW store. Last 5 months been used by Daughter for work with 0 issues. Much work done while I have had it and will list below.
It's is not perfect by any means, the issues I can think of are:
Door locks getting tired - if you toggle them enough generally they work eventually, I think I have a bag of 5 motors though still need to find them.
Running boards, have them, but they are off and I cannot find the bolts, so a trip to ACE will be needed
Steering wheel tilts, but telescope does not.
Antenna broke off, still can get stations mostly, I have a new antenna just not installed.
Hearing some wind noise from the top of the front doors. Probably could use door seals...
Tired front leather..
Just remembered one more thing - the tube from the center hvac to the driver side is gone - was when I got it. Just means that left vent on driver side doesn't blow - all others fine. Reckon you could yank one of those for almost nothing off any just one no problem, just a plastic air tube. Never bothered me..
The only bugger issue I've had was for a couple years the truck would stumble in really freezing weather. Like under 15 degrees. I worked through and replaced the TPS and all the plugs and coil packs (tried generic at first, but eventually caved and got Denso) and it hasn't happened since but not sure how cold it got after....
Now Good Stuff!
Clean Title
Timely oil changes
Passed emissions test 9/29/23
Tranny and diff fluids / lube at 204k 1/2020
Radiator and AC condensor at 219k 7/2021
Timing belt/waterpump at 227k 1/2022
Steering rack tie-rods at 230k 5/2022
Front brakes bearings and front control arms at 231k 8/2022
Tires - Cooper discovery 8/2022
Rear rotors/pads - just a couple months ago in my garage
Never radio with apple/android
Running boards (not installed)
extra set of 18" tundra wheels (bad tires)
All seats present
AC / Heat good
AHC works!
that's it! Just want it to find a good home - will start the sale at 9,000.
Status
