SOLD 1997 LX450 Triple Locked, 205,000 - $22,000
Year
1997
  1. 80 Series
  2. LX450
Mileage
205000
Color
Black
This truck has been owned many years by a good friend of mine. He took it apart almost 4 years ago to lay Dynamat in it and had a life/career change and it got sidelined.
I grabbed it 4 months ago and have been working out all the bugs from sitting up
* disclosure …. I am 99% sure I know what is good and what is bad with this truck. The listing is what I know and what I feel good representing
205,000 Miles
Zero Rust
Front/Rear Factory Electric Lockers
4x4 Labs Rear Bumper
New 315/75r-16 Cooper ST Maxx
New IronMan Foam Cell Pro 3” Lift
Driveline
Complete Axle Rebuild Front/Rear
-New OEM axle shafts front and rear
-New Terrain Tamer birfields
-New 105 series roller bearing spindles
-Knuckles rebuilt with koyo bearings and OEM seals/ gaskets
-New OEM drive flanges
-New OEM wheel studs
-New OEM tie rod /relay rod ends
-New OEM brake rotors, pads, and remmaned calipers
-New OEM extended brake lines
-New OEM driveshaft u-joints
-105 Steering Gear
-New OEM proportion valve
-MAF caster drop bracket
Engine
-OEM hoses and Belts
-Pesky Heater Hose Bypass Kit
-New Battery
-New HD battery cable kit
-New OEM Fuel Pump
-New OEM Fuel Filters
-Freshly cleaned fuel tank
-New Exhaust
-New Wits End PS cooler system
-New motor mounts
-New blue HD fan clutch
-OEM hand throttle
-OEM thermostat
-OEM water pump
-OEM PCV refresh
-OEM plugs, cap, wires
Resealed Oil Pan
-OEM Valve Cover Gasket
-OEM vacuum hoses
-New OEM Coil
Interior
-Fully sound deadened with Noico insulation, Floor, Sides, Roof
-New full carpet kit with rubberized coating and jute
-LX Oak interior with very good condition plastics
-100amp rear auxiliary power
-New Pioneer single din stereo with 4 speakers
-New 100% leather seats via Land Cruiser Heaven
Cons.
The roof and the hood could use paint. The passenger rear door has a dent. No worry of rust but if the look is not for you, plan on paint
It has no key fob. Just a master key.
It used to have an entertainment console so there are holes in the headliner (still available OEM)
Needs a hood insulator (still available OEM)
It’s 26 years old.
Pros.
It drives superb. Tracks great. Rides great. Not too many rattles.
The seats are great. Super comfy. Drivers side gear was replaced and it works properly
Underpriced
I didn’t overpay for it but I’ve got a lot of time and OEM parts in it to get it ready to sell.
Will wants it bad.
Mainly because it’s clean. He would blow it up after having the 100 to abuse the last 3 years
