1996 rear load sensing proportioning valve issues.
florida
hello everyone im new the forum thanks for having me. im having some issues with the rear load sensing proportioning valve it seems to be leaking brake fluid from the load sensing spring right were it connects with the valve boot . im in need of any sug gestions i called the dealership and there asking 230 for the part . also my brakes get hard when im pressing down to brake i wont be able to drive
please help thanks,
I had a little fluid leaking from the boot around the rod going to the rear axle. I used a small zip tie on it and haven't had a leak since. Is that the place you're talking about?
well i am parting out a truck or 3 can hook you up with the part. if you want to go used message me and we can get something going.
stiff brake pedal could be a failing brake booster. I also have a spare LSPV in case slow95z doesn't have a good one.
