Build 1996 LX450 6.0L LQ9 Swap
I dont not have a profile for the camshaft. Currently I have a local guy who is sharp as a tack do my tuning for me via HP Tuners. He does it live in the vehicle for optimum result, so he not only sees the tune but feels how the car responds. Ill look through our paperwork on the cam, it has a wide powerband.
If there is any chance you aren't gonna have ac I am in need of the little whit box under the steering column.
Swap will be awesome by the way!
bead blasted some of the accessory brackets
Comp cam chromo push rods and Scorpion roller rockers set in place.
Mañana she gets dressed and place in the rig. Also getting the injectors rebuilt and cleaned. More pics to follow
Test run (I guess my thumb was over the dang mic...). Sounds strong! Can't wait for the hot lap :D
What did this motor originally come in and what are the stock specs ? Sorry if you've already posted this information, I have read through this thread once I promise.
This motor was available in the Yukon Denali, Silverado SS and Cadillac Escalade (and a few others). I have done a bunch of reading on it and it is a popular motor because of the cast iron block (can handle higher horsepower than aluminum) and flat top pistons. The LQ4 is almost exactly the same, but with dished pistons and lower compression (therefore less power).
It features high-compression (10:1) flat-top pistons for an extra 10 hp (7 kW) and 10 lb·ft (14 N·m), bringing output to 345 hp (257 kW) and 380 lb·ft (515 N·m)
http://en.wikipedia.org/wiki/General_Motors_small-block_engine#LQ9
Jonathan upped these numbers by installing the Comp Cam, Titanium (double) valve springs, roller lifters, chrome moly pushrods and Scorpion roller rockers. Not sure if the Hooker headers and 3" exhaust added much, but I am hoping for about 400 HP when all is said and done.
This particular motor was a crate motor after the original motor was found to have a seized cam bearing, stuck lifter, was an LQ4 (not an LQ9) and had almost 3x as many miles on it than the seller stated. That motor is going to sit for a while, but will probably be rebuilt into an LQ9 by replacing the pistons.
All that being said, I didn't know sh!t about motors until Jonathan started this project with me, but now I know a bit more...
Yeah what he said ^ lol
400hp is easily obtainable with our mods. Where we will really squeeze it out is through the tune.
